Zenith Carb Woes
Ok, my 68 Landy 88 has been running great. I put a new zenith carburetor on just 50 miles ago. Has been working well until this morning. Started up and then died soon after. I found out that fuel is bubbling into the carb throttle area on its own even when not cranking. So I believe it is flooding. Keeps doing it too. Is this a stuck float valve? I am not familiar with these aftermarket carbs, but after two of these carbs with problems in both, I am beginning to wonder if they are junk or I just have bad luck. Any thoughts on what to check?
Thanks in advance. Jim
I am sure you have corrected this in the last year. My experience with Zenith was similar. I pulled the carb apart and adjusted the floats to reduce the amount of fuel in the bowl. It seems to be working after two days of driving.
