1995 disco goes into reverse and drive ETc. but does not move!! HELP
My 1995 disco which has sat quite a while due to engine rebuild has really got me puzzled. At same time during engine rebuild I replaced rotors and brake pads. Now when I am ready to get the disco out of garage I crank the engine and shift it in to reverse or drive the vehicle does nothing. It is not shifting into gear nor is it moving. My four wheel drive gear shift goes left or right but does not move up. PLEASE HELP!!
disco 1 not moveing when in gear
thanks for the response. my four wheel drive will not shift into high or low. It is stuck in neautral which makes me think this is reason why rover will not move when in drive or reverse. i am going to try lubricant this weekend or take center console out. There is a plate with rivets that gives you access to linkage on top of transfer case! do not think it is pump at this time. Thanks
