3 Attachment(s)
96' Discovery - 5 speed, winch, 70k mi.
Selling my 96' Discovery with 5-speed manual and 70k miles. I've enjoyed driving and working on it but need more of a daily driver. I built the sliders and winch bumper and installed the on-board air. I have a new detroit truetrac LSD in the rear axle. It has loads of new parts and a great maintenance history. The engine was rebuilt with a new Bosch engine block at 40k by Robison Service (I have documentation of the work). Everything that needed work or replacement was attended to. I have treated any rust over the years in the usual places but the truck is very solid. All the hubs and the swivel balls have been rebuilt. The work at Robison Service included:
-new engine block rebuilt with new injectors, fuel rail, updated carbon cutting valves, updated PROM, and all that was needed.
-new clutch at same time (40k miles)
-AC recharged
New parts and jobs I've done:
-4 new bilsteins this year (with receipt/warranty)
-4 reman. calipers, new rear rotors (brakes work much better)
-swivel balls completely rebuilt with new seals, flat bearings and washers
-cooling system hoses, reservoir
-PS lines are new genuine
-oil cooling lines, new genuine (I added a wrap for more protection)
-water pump is new (not Proline) and belt
-truetrac rear diff
-superwinch EP9 (brand new)
-sturdy winch bumper with dual recovery points
-Quick-Air 2 with 2.5 gallon tank/ custom skid plate
-fuel tank and pump
-rear cargo liner with disco 2 tie downs
Older parts that were replaced:
-gear reduction Denso starter
-borla ss exhaust
-rockware trailing links
-optima blue top
-ARB headlight wiring harness upgrade
-brake master cylinder
-bearmach hd drag and track links, OME damper/relocated
Probably more I'm forgetting. The truck is very strong and the R380 gearbox shifts perfectly. Once in a while I will get a high idle when cold but it always adjusts. CDL works as it should also. Everything works. Sunroofs are sealed and the windshield is new. Fluids have all been changed frequently. The truck will last a long time. E-mail me for more info or pics- roverfolly@aol.com. Truck is located in MA. Asking $6500. Thanks, Dave
