Does anyone know if there are distributors of wolf rims in the US or Canada?? Or does anyone have a set of 5 they want to sell??
thanks
thanks
Hello there,
Our hosts have these in stock :-
http://www.roversnorth.com/store/sea...rchTerm=plw216
:thumb-up:
ahhh, thanks mate. Do you know are those the tubeless wolf rims?
Why, yes they are.
Were you looking for the tubed ones?
Correct me if I am wrong, but you can put tube and tubelss tires on tube rims, but you cant put tube tires on tubeless rims. I figured might as well get the tube ones so that I can fit what ever I need on them.
Also do you guys do the Terrafirma tubular winch bumper with the A bar, or could u order one?? (thinking about a purchase over summer)
You can put any tire on any rim. You need to use a tube and flap on a rivetted rim, regardless if it's a tubed type tire or tubless. People have successfully used rivetted rims without tubes, by puting a dab of silicone sealant over each of the rivets.
If you're running welded (tubeless) rims, you still need a tube inside a tube type tire, but don't need a flap.
To add to Terry's comments, on some rims the hole for the valve may need to enlarged as opposed to the inner tube valve stem. :)
So I want to see if I understand this all correct if I were to buy the wolf tubeless jobs I could throw on my tubeless off-roading tires or a set of on-road tube tires???
I have a set of good tubeless off-road tires and want to throw them on the wolf rims due to their extra strength. and use my old set of rims for some slightly smoother on-road tires.
Thanks very much for the info Terry and Les!
I have run tubes on Wolf rims before and the valve stem holes are extremely tight with tubes.My local tire shop guy has quite a colorful vocabulary! I chose not to enlarge the hole as I planned on changing back to a tubeless setup eventually.
