greeting fellow rover enthusisist! i just recently purchased a defender 110 with a 2.5 diesel n/a..... does anyone know what kind of motor oil it takes??? what about the tranny and diffs?
thanks you very much!
In the LT 77 or R 380 Gearbox use MTF, axles/Transfer box : 75/90w Hypoid oil, engine/filter 15-40 (we use Amsoil on all of these )
Les.... Thank you! Also.... WHat is "MTF"?
MTF=Manual Transmission Fluid.
It's not the same as Dexron ATF.
I use Redline MTL in the gearbox.
For motor oil I used Drydene Dieseall for many years, now owned by Castrol.
Shell Rotella T would be good.
one more thng .... does anyone know what the oil capacity of the 2.5 na diesel????
5 litres is just about perfect on mine.
The manual states 7.23 US quarts with a filter change.
It will vary by about a pint depending on if you're using long or short filter.
thanks.... cause 5 qts wasn't cutting it !
