does anyone know if the series 2 wheel bolt pattern is the same as a discovery. i am worried if the warn hubs would not clear if the wheels bolt up. these would be for snow only
The bolt pattern of the S2 is the same as the disco (1) but you can't put a disco wheel on the S2 as ther hole in the center isn't large enough to go over a Warn hub. You have to stick with steel wheels.
The Discovery I steel wheels fit just fine over Series hubs. Nice and strong too !! I have them fitted to my Series III Airportable.
Steel wheels will fit, but not the fancy aluminum ones due to the afore mentioned center hole.
The bolt pattern is the same, however, the studs are larger on SIII and disco's.
