Need Help/ Troubleshooting 95 D90 V8 fuelpump/relays
Took the 1995 V8 D90 for a spin, its been awhile.. I revved the engine driving on a straightaway and all of my electrical/lights surged then went out, along with the engine. my lights/electrical came back online after the momentary outage but the engine had quit. the 7.5A fuse had blown and the fuel pump was not priming when I turn the key.
Currently I have replaced the 7.5 fuse, both under seat relays, hotwired fuel pump and it runs 4.0, checked fuses under bonnet and pushed inertial switch.
-I am not getting power to the 7.5 amp fuse, the "Blue base" fuel pump relay is getting power to the 30, in an attempt to get the pump to prime I connected 30 to 87/87 on the relay and nothing happens.. saw that in a troubleshooting forum elsewhere.
I know I need to start checking pins on the ECU but am looking for some general guidance on how to trace this electrical problem.
thank you for the help.
-Brent
