Clutch doesn't disengage?
1972 Series III 2.25 petrol 88". The clutch pedal became "softer" progressively but fairly quickly - over just a day or two. Then I started it in neutral and tried to drive but it wouldn't go into gear at all.
New master and slave cylinders installed, all unions renewed, well bled and no leaks in the circuit. But pedal is still very soft and will not go into gear when the engine is running. Fearing something else very horrible is broken. Is there anything else I can check visually? The throw out bearing and lever are well hidden unless I am looking in the wrong place/way.
Your advice will be much appreciated.
