Brake fluid leaking at petal inside-servo /mc issue
1972 LAND ROVER SERIES 3 88.
RECENTLY REPLACED MY BRAKE MASTER CYLINDER DUE TO LEAK BETWEEN MASTER AND SERVO. SOON AFTER A VERY SMALLLEAK DEVELOPED BY THE BRAKE PEDAL ( DIRECTY BEHIND) LEAKING ONTO FLOOR BOARD. THE MASTER BRAKE CYLINDER SHOWS NOT SIGN OF ANY LEAKS AT THE UNIT. CHECKED THE CLUTCH FLUID LEVEL AND ALL IS GOOD. IF THE MASTER CYLINDER HAS A BAD SEAL CAN IT LEAK INTO THE SERVO AND THEN FIND ITS WAY TO THE BRAKE PETAL BOX? ITS ONE OF THOSE " I JUST PUT A NEW BRAKE MASTER IN IS IT REALLY BAD ALREADY" . ANY ADVICE WOULD BE SO HELPFULL.
ps - THE LEAK IS SO SMALL BUT IMPORTANT I CAN NOT SEE THE MASTER CYLINDER FLUID GOING DOWN AT ALL.
