In Regard to Electrical/Issues
Yes, dialectric grease a must. I use it to an advantage but I have a question concerning a problem I've had ever since I got our Classic.
When the vehicle is running, all the lights, inside and out flucuate with pulsing intensity. I have cleaned the battery connection and check for corrision where it is evident. Have checked the battery and the alternator output and both are performing at factory specs.
When driving sometime after appling the the brakes the pulsing will stop,sometimes deminish and then continue when I let off the brake. I know I need to check the other ground connections that I havent done yet and I have adjusted the v-belts at the power steering and alternator
with no obvious change in the simptoms.
Thanx for listening, any comments would be much appreciated.
Burt with the 91 classic !
