Engine Timing
Truck is idling a little high...clean the idle air control valve (that helped some....) They have told me the timing is out a little which could cause it to idle higher. Can someone tell me how to adjust the timing?
Trying to get the car smogged and they will not pass it because the idle is not with specs.
Thanks for the help
There is no way to time a P38 Range Rover. There is no distributor!
Timing
Ok..thank you.
Can you tell me what is done in the place of the distributor?
Coil packs and an ECU that controles Ign
Thanks Kevin
Thanks for the information
