I have a 2.5 NA in my 88 and wouldn't trade it for anything. So to each his own.
Jim
Jim
Now that I have all the piece parts necessary to reassemble my engine I was wondering about the crankshaft main seal. As you can see from the picture, it looks pretty clean in there (I've not cleaned anything), but it comes under the "While I'm in there" category.
http://www.flickr.com/photos/3127781...n/photostream/
Is it simply a matter of pulling the crankshaft gear and pulling out the old seal with a screwdriver (Drain oil first???)? I've got the seal already but I'm paranoid about keeping everything lined up for timing. Hoping to have time this weekend to put the injection pump, water pump, lift pump, belt, belt tensioner all back on and if it's really that simple I guess I should replace the seal.
Thanks,
Geoff
Wow. That IS clean!
If you bought the pump timing kit, I suspect that it included the pin to lock the flywheel in place.
It doesn't really matter, because it isn't too difficult to time everything using the marks on the cog wheels and on the timing case even if things DO get moved around a bit. (unfortunately, I know this first-hand). You've got to time it up to reinstall the injector pump anyway, right?
Looking at the bible, I'd say that the biggest PITA is removing and replacing the seal with the crankshaft in the way. Probably have to get just the right size pipe to install the new seal, unless you have special tool 18G1456 lying around.
BTW...I wouldn't worry too much about draining the oil--It's all in the sump below the crankshaft anyway.
yes, replace the seal. You'll be really bummed if you put this all back together and the $xx.xx (cheap) part fails and contaminates the timing belt and you have to go back in and do it all again.
Its easier if you pull the front cover off (the one that the IP bolts onto) and you'll run less chance of damaging the end of the crank with the digging impliment used to pry out the seal. Re gasket that all while you are at it. Keep track of which fasteners go where.
Thanks for the quick reply, few questions:
1) I know this first-hand). You've got to time it up to reinstall the injector pump anyway, right?
What exactly does that mean? I carefully scribed lines in the injection pump/timing case, locked the flywheel with that VERY expensive tool, and lined all the marks up on the gears/timing cover. I was hoping just to put everything back in place and it would magically be timed correctly. I'm guessing that's not the case and if so guess I'll dig into the bible and see what's involved.
2) In reading the bible, what is the double tensioning? Set the tension, crank the engine through two revolutions, slack the belt and repeat?
Thanks,
Geoff
Regarding keeping everything lined up timing-wise--Let me rephrase: Getting the timing marks a bit out of kilter while fiddling around with the seal won't matter much, so long as they're exactly lined up when you install the timing belt.
Your understanding of the double-tensioning procedure is correct.
TIP: Make sure the timing marks on the cog wheels and timing cover are still lined up AFTER double-tensioning. I swear mine were lined up on all 3 marks before tensioning. I put the whole thing back together without re-checking the timing marks after tensioning the belt. I even added coolant before I attempted to start the engine. Well, it wouldn't start and backfired horribly while cranking. I pulled apart the entire thing to find that the cam sprocket was now clearly 1 tooth off (7 1/2 degrees).
The next time, I (very briefly) started it after double-tensioning the belt and before I put anything else on!
Matt is right about the main seal being easier to change with the entire timing housing removed. If you go this route, remember that there are some gaskets between the timing housing and the block that'll need to be relpaced.
I have a 2.5, it sucks a lot! But it always starts and has only left me stranded once. A 35$ head gasket was cheaper than an engine swap so I kept it.
