Thanks guys!
After verifying that there were no electric wires connected to the pump, I went ahead and did the POS to NEG earth conversion last night.
disconnected batt
had to re-position the ground cable
swapped wires on the ammeter
swapped wires on the interior LEDs
swapped wires on the ignition coil
re-polarized the generator from the POS batt terminal
inserted batt in reverse position and connected
Result:
truck starts and runs
ammeter still reads (-)amps
LEDs work
charge light is still on
So basically the truck functions exactly as it did before the conversion.
I'd say that's a success?
Awesome! Nice work and welcome to negative earth.
My 61 still has the original generator and at over 85,000 miles it's still working fine. I'm thinking it must be constructed from Roswell materials.............
If you took your generator apart, you would find it to be a pretty simple device. To those reading this far, the consumable part is the brushes and they can be found for $8 to $10. Also - there is a small oil hole on the engine side/very center of the generator's circular end cap. A few drops of sewing machine oil in there goes a long way. Probably a good idea to have a spear bearing handy too.
