Not shifting into low gear
Question about the transfer case. I have a 1995 disco I and I can't get it into low gear. I took the top cover off the shifter and it has a rubber boot over the shifter. Can I cut a hole in the rubber and spray with pb buster that way or do i need to take the console out an do it properly?
Thanks,
Chris Archer
1995 disco I
help flange nut on front drive shaft and rear brake drum 95 transfer case disco
has any one removed the flange nut on front of transfer case or flange nut on rear brake drum of 1995 disco. the picture in this forum shows nut on front drive shaft flange. thanks
