Help Changed Plugs and Engine Won't Start
I changed the plugs in my '94 D90 with Bosch Platinum+2 (part 4306). I was careful to re-connect each plug wire as I went along.
I finished up and cranked away but the engine does not start...
The engine was running before the plug change.
Any thoughts?
Not sure if I am getting a spark...
I put an extra plug into a couple of the plug wires and tried cranking the engine. With the plug laying on metal I thought I should see a spark jumping the gap in the plug - I did not...
I tried disconnecting the lead from the coil to the distrbuter and laying it on some metal in the engine bay. When I crank the starter, I am not seeing any spark.
Does this sound like I am checking properly?
My next step is checking the coil/components.
