3 Attachment(s)
1967 Series IIA 88" Station Wagon For Sale
SOLD!!!! Thanks.
Decided to sell my '67 IIA Station Wagon, after extensive rebuilding.
Classic safari look. Paint originally red, but quite weathered. Looks great that way. Wouldn't change it.
Currently registered & inspected. Runs beautifully. Very good highway speed.
Always gets a lot of attention.
Features include:
Rebuilt (2009) 2.25 litre petrol engine
Frame coated & rock solid - no rust
Bulkhead solid
Safari roof hard top with alpine glass & sliding windows
Elephant hide interior (complete) – door panels, 4 jump seats
New front seat bottom cushions
Full headliner
Military 2nd gas tank
Optional oil cooler & grill screen
New tires & rims
“D” rings on new front bumper
Power takeoff governor
New clutch
Rebuilt master cylinder & pedal assembly
New stainless steel brake lines
New front & rear brake wheel cylinders and shoes
New Old Man Emu shocks
New LH & RH ball joints, clamps, track rod tube
Side & Rear steps, trailer hitch w/ electrical socket
Land Rover logo mudflaps
Kodiak heater
Hood mounted spare & rear spare mount
Hand start crank
Extra new rear crossmember
New wing mirrors
Front vent screens
Roof-mounted rear antenna
New fuel pump
New distributor cap, wires & coil
Rebuilt carburetor (Rochester)
Emergency flashers (dual switches)
Wipers with hand operation levers
Windshield washer & new bottle
New radiator hoses and fan belt
New brake line hoses (stainless steel)
Recent work completed:
• installed rear axle check straps
• laundered & reinstalled original seat belts
• completely cleaned & refitted interior
• new shift & brake boots and knobs
• installed new fresh air duct
• refinished rear view mirror
• repainted roof vent surrounds
• all door locks in working order
• sliding windows in working order
• new front seat bottom cushions
• dome light lens
• new defroster hoses
• installed spring & base on 4-wheel drive lever
• centered steering wheel
• new wiper arms, adapters & blades
• new speedometer cable
• new battery & terminal connectors
• steering box gaskets replaced & resealed
• transfer case rear seal replaced
• new signal light switch installed, lights/sockets rewired
• new rear hub seals
• new brake wheel cylinders & rear brake shoes
• new high pressure oil hose to oil cooler
• tropical roof cleaned
• radiator resealed & repainted
• radiator panel – new metal at bottom, repainted
• battery tray & horn – wire brushed & repainted
• interior & exterior trim pieces repainted
• rear crossmember, plate light casing, hood tire plate repainted
• new clutch plate, pressure plate, throw-out bearing
* flywheel resurfaced
* master cylinder & slave cylinder rods and pedal correctly adjusted
* Land Rover logo mudflaps installed
* New voltage regulator, signal flasher unit and electrical wiring improved
* New heat blower switch
* New front running & signal lights - lenses, sockets & wiring
Price: $9,999
Located in Albany, NY
For additional photos and any questions, please email to: goaler29@gmail.com
2 Attachment(s)
Additional photos attached
Installed new voltage regulator, signal flasher unit and improved electrical wiring and connections
Running very well with great highway speed
Forgot to include that the IIA also has new left-hand and right hand threaded ball joints (tie rod ends), clamps and a new track rod tube - very tight steering
