Cheers, what would be the proper setup for windscreen washer apparatus on an ex-mod series 2A? I have the nozzles with pinholes at the windscreen, have green hose,,,
Not sure what you're looking to do. If you don't have the pump and reservoir, maybe go to the junk yard and pick a suitable bottle and pump combination. Then just add wiring and a switch? As far as the stock setup goes I don't know, my SIII was changed to a more modern setup long ago.
'99 Disco II
'95 R.R.C. Lwb (Gone...)
'76 Series III Hybrid 109
'70 Rover 3500S
So the bottle with the motor is period appropriate? I have one of those. Ike had a knob with a "push plunger", I thought was cool, one could avoid using electricity with that set up. Thanks.
