92 RRc
92 rr non abs $1,000,000.00 cash only:D
or will part out
SG f+r bumpers:
front w/out skid w/ 2 d-rings set up 4 warn winch $500
rear w/alum skid blasted and painted w/ por 15 $550
Allmakes alum upper tailgate w/ defrost needs your trim to complete $350
Hannibal roof rack w/ jerry can mounts never installed + high lift mount installed $750
ECR tie rod guard, bolts on where radius arms are, can be used as jacking point $300
SG sliders, needs paint and plates welded to sills to mount $50
Rovertym 5"lift : springs, cranked front arms, rear links, rear upper and lower shock mounts, front lower shock mounts, rear cones, 7100 series remote reservoir shocks 12" travel 310/80 valving, 2" a arm extension, adjustable heim jointed pan hard rod. make offer
Local pickup only please, New London,Ct
Ed
if this is the big silver one i am thinking of, what kind of shape are the tires in? If I recall correctly you had a set of super swampers, would you be interested in selling those?
Thanks,
-Rob
Tires have some dry rot,you have dibs after it's parted.
Ed
I apologize for all of the questions, but what set up are you running in the axles and are you interested in parting with those?
are you attending british by the sea at Harkness park this weekend?
-Rob
Hi Rob,
The rear is macnamara vac locker 4.1r+p w/ their 24 spline shafts, the front is gbr open reverse cut 4.1 r+p w/ gbr/ maxi drive 24spline shafts and 1 ton type hardened cv's . Sorry not for sale at this time, saving for another project.
Unfortunately I have to work Sunday + won't be able to get to Harkness.
If you know of anyone that is looking for bumpers or a rack for a RR or a lift for a RR/ D1 send them my way.
Regards,
Ed
I have a friend interested in the roof rack if it is still unclaimed, do you mind if I swing by and take some pictures of it?
-Rob
No problem, the jerry can mounts are in my garage, along w/ the rear section.
I'm interested in the rear bumper and sliders if still available?
You are second on the rear bumper, 1'st on sliders I will be pulling parts this weekend. PM me your email and I will try to get pics to you.
Also have a NRP ss exhaust including cats/y pipe available.
Ed
