I have an 84 110. What Land Rover wheels will fit this unit? Thanks in advance.
pretty much everything from steel series wheels up through Range Rover and Discovery alloys. Discovery 2 and P38 range rovers have a different lug pattern. Depending on what hubs are on your axles some of the different alloys may or may not fit with the center caps in. I ran a set of Deep dish alloys on my 83 but without the center caps. I later switched to the aftermarket hardened type hub flanges and the wheel center caps fit.
Thanks. Found a good set of alloys on eBay. Now to sell what I have. Thanks again.
Beware ! If you have rear drum brakes, alloy rims from a Classic/Discovery I will not fit correctly over the hubs.
Either machine the centres of the wheels to fit the hubs or fit alloy wheel spacers.
RN # RNWS001 Spacer kit.
Wow, that price takes all the fun out it. Is it possible to only purchase 2 for rear only instead of a set of 4 ?
That would make the rear a wider track than the front, also, the front hub ends would stick through the alloys, so you would not be able to put the centre caps on.
In short, it's advisable to fit all 4
I run just 2 up front to clear the radius arms and it runs great.
I have read that the bolts on the spacers need to be tightened/torqued regularly. Do these come lose over time? Are there any other issues to be aware of?
I want to use newer style wheels on my 1986 D90 but have been hesitant to use spacers.
