Otter Switch for Choke Light
Quote:
Originally Posted by
mikeshaw247
Yep - I need this otter switch. I believe it is part number 545010 called a Thermostat Switch or Choke Light Switch. Different from the switch on the cable, which I removed. The switch on the cable tells you the opposite of what the Otter switch tells you. Otter switch says - hey - use your cold start. Switch on the cable says, hey, push in your cold start cable. Hard to find the otter switch. Rovers North doesn't seem to have it anymore.
Thanks!
Mike
I did find one. Yep - called Otter Switch, it seems everywhere. Now I just need to test mine to see if it's really broken.
Thanks all!
Mike
