8 Attachment(s)
93 NAS D110 #52 in Black for sale
93 NAS #52 D110 Black
$62.5k Firm
Other than the color, ARB Bumper, Warn Winch, the usual OME spring and shocks, and Stereo this is a pretty much stock D110. I bought 12 months ago and fixed a variety of things and have sparingly put about 4k on truck. Represented to me, Auto Check verified, as a South Cal truck till 2006, 6 years in Michigan before going back to LA and then spent the last year in Central Illinois. Everything works as it should, the frame is clean. Slight bit rust on forward bottom of 1 rear door and others are good. The paint is fair to good; very presentable, but not without a few flaws. I am not a black car guy and never appreciated the color. A very little amount of aluminum corrosion above the gutter on driver’s side, and under rear window on passenger side. Engine compartment, floors, and here and there is the original white paint. The cage has 1 or 2 runs in the paint if looked at closely. Suspension is tight and drives very straight. Engine has 146k honest miles. My guess is the engine has been very well taken care of and runs without any issues, and has no oil leaks. The engine starts a little slow by my standards, but never fails to start. Tires have less the 500mi on them and the spare is new but a different make and model of the same size. Clutch was new when I purchased truck and transmission feels perfect to me. The interior is basically stock. There is double carpet everywhere-I just left it that way. Drivers is worn on the beaded door edge, and there are 3-4 1" little rips/snags in the vinyl back of the rear bench. Everything is there...even the little green ac button. Two of the vents have fins that do not go up and down, they just hang loose. No heated windscreen and I scratched the glass just above where rearview mirror attaches in a sloppy attempt to rehang it. Headliner is all there but fabric not tight with backing...aka-sags 1-2". Front drivers door card has kick marks on bottom, and center cubby has rubbed through corners. Lots of Dynamat.This truck is not perfect and feel I have represented it very accurately. Feel the truck is fairly priced and will answer all questions to the best of my ability.
Prefer Email
SGStriglos@Striglos.com
