2001 4.6 Battery Change problems
I recently changed the battery in my 2001 HSE. Since then the radio only partially works, I can select stations but can't adjust the volume. If the key is not in the ignition, the stereo and the volume control on the steering wheel work fine. A soon as I insert the key in the ignition, the front speakers stop playing and I can not adjust the volume. Only the rear speakers work. In addition, the GPS screen is blank, and the power light on the unit in back does not come on. The unit will repeatedly eject and pull the disk back in but wont function. Any ideas what is causing the problem, and how I can reset/repair them? It seems like a short or loose connection somewhere but I have no idea where to look. Any ideas?
