TigerDan,[CENTER]
Look below, you will see you are good to go on the rears, but they have installed the wrong ones in front. They probably installed rears in the front too. This is a typical way of achieving 3" of lift in Rovers, but they didnt do it right. If you cant tell what they are, order two new fronts from the chart below to match them correctly. Go on the ExpeditionExchange website(https://www.expeditionexchange.com/ome/indexsprings.htm) for good explanation of all the possible combos for OME springs. The vibration is from the horrible pinion angle you have up front and it will lead to ujoint failure eventually.
Part No.
Axle
Rate (lbs./in.)
Recommended
Application
Length (DS)
Length
(PS)
Resulting
Lift
760
Front
180-250
Light Duty (under 0-50 lbs.)
15.1"
14.6"
2"
FONT=Verdana]761 [/FONT]
Front
200
Medium Duty (50 lbs. to 110 lbs.)
15.7"
15.4"
2"
751
Front
230
Heavy Duty (110 lbs. to 250 lbs.)
15.3"
14.9"
2"
766
Front
280
Extra Heavy Duty (220 lbs. to 350 lbs.)
16.6"
16.6"
3"
764
Rear
220
Medium Duty (unspecified)
16.9"
16.5"
2"
781
Rear
290
Medium/Heavy Duty (unspecified)
16.7"
16.3"
2"
762
Rear
300-340
Heavy Duty (220 lbs.)
16.5"
16.1"
2"
763
Rear
360
Extra Heavy Duty (440 lbs.)
16.5"
16.1"
3"
Cheers,
Jack of Bavaria
