LED headlamps?
Can anyone suggest a particular LED headlamp to replace the 7" sealed beam lamps in my 1980 series III ? I'm looking for a headlamp that looks like a headlamp... most of the stuff on the market is styled like something out of a bad science fiction movie. Tx.
In order to keep the period correct look, I have the Hella Vision Plus lamps. I replaced the halogen bulb with an LED bulb that I bought on amazon. I read all the reviews and wanted CREE bulbs. Look for these: HIKARI LED Headlight Bulbs Conversion Kit -H4(9003)
I also replaced the steel buckets with the Wipac plastic buckets and have the stainless steel trim rings that I got from eBay UK. Headlights very bright and use less amps.
I do have them on a relay.
Just did a quick search on eBay. In the search box type in halogen headlight 7". I found a couple sets of H3 headlights for around $20. You just want the reflector housing anyway.
Many thanks for that suggestion! I found the parts on Amazon. Did you have any issues with flicker?
