BAD STARTING 3.0 DIESEL BMW ENGINE
2003 MODEL.has any one come across bad starting from hot or cold, it will start but you must , crank for over a minute, yes is the fuel runing back, change fuel filter and check connections, looks like fuel in plastic line, no bubbles , i think poss weak fuel pump, because if you jump it and the engin spins fast it will start ok, untill you leave it for 4+ hrs, some times its a pig only after 5 mins?
the other pain is the viscoss fan sounds like it a plain, so replace it still the same, then it was ok for a hr, are there flaps or switch that open and close air vents on or off ??
RANGE ROVER 3.0 DIESEL BAD STATING FEELS LIKE FUEL
ANY ONE OUT THERE COME ACROSS THIS
