i have managed to sort this out via a specialist who said its a software glich
Danny,
What issue did you have?
All my switch lights are lit and the Rover now has a forward rake to it, it's high in the rear?
Anyone?
Charles
Try turning the steering wheel lock to lock.
Thanks, i'll try that.
Can you explain the method?
Charles
When you start the car, turn the wheel all the way left and then all the way right. This should reset the air susp. If not, then you might have a steering angle related issue or air susp faults.Quote:
Originally Posted by avaiojet
or when you undo the battery, you have to drive it ten or so feet (as the owners manual says) to reset it and the hill desent control light.
