03 Disco - loud noise from pwr steering system
Hi All,
I've got an 03 Series II with the 4.6l engine & ACE... I've been noticing an increasingly louder "growl" when turning the steering wheel. It actually sounds a lot like a hydraulic cylinder activating under load. BTW - noise is louder when sitting still - I assume this is because its harder to move the wheels when not in motion.
Is this indicative of power steering pump going out or something a little less sinister? Not experienced at all with steering systems, so HELP! :confused:
oh - vehicle just shy of 60k miles.
Thanks!
03 Disco with noisy steering pump
I checked the reservoir, and forgot to include that data... the power steering fluid reservoir is about .5" lower than the "low fill" line... I haven't driven it since I noticed that, because I haven't been able to find the power steering fluid specified in the manual, and it says the pump could be damaged by insufficient fluid.
So... have I damaged the pump? or will filling the reservoir to the "fill" line take care of it? Seems like an awful small margin of error - less than a pint, I'd estimate - especially when there is no warning indicator (aside from the growling its started to do!)
And where do I get the power steering fluid - the manual is very specific, and no auto parts store I've talked to has a cross reference for the fluid specified (Texaco Cold Climate PAS Fluid and a GM equiv. part) I figured I'd have to get it from the dealer, whose service dept. has been closed since Friday!
