Slight miss - 2.25 Series 3
Hey all,
Brought the Rover in for a tune up after a .... long.. break from her. I’ve replaced the following with new parts;
Carb and filter
points
condensor ( 1st new one was bad.. that was fun figuring out )
rotor button and cap
plugs
wires
fuel pump
spin on oil filter conversion
I also adjusted the valves to the recommended .010 (cold, however I’m told it’s best hot)
She runs great however every 3 seconds it putts from the exhaust and at high RPM you can still hear that putt. It’s almost like it has a bit of a miss. I’ve rechecked the points and plugs and am confident I’ve tried every degree on the disty but this silly annoyance won’t go away. Any thoughts or suggestions would be appreciated !
