4 Attachment(s)
1995 Range Rover Classic LWB
Loads of new stuff. Runs smooth,engine is spotless.,no grease or grim layers on top and intake.153k miles,automatic,4X4,clean,no tears in leather seats.Very solid truck.Old Man EMU 1.5 modest lift with Bilstien shocks,new Bilstien steering dampner,front brush guard with Hella lights,new factory head gaskets,new water pump,new camshaft,gears,timinig chain and lifters..All new cooling hoses,belt,plugs,wires,vacuum advance,all new power steering hoses,new battery,new Cooper Discovery AT3 245/75-16 tires.New exhaust system.All of these items in less than 1500 miles.Also I just installed a pristine rear upper tailgate from Land Rover(not aluminum aftermarket) that is included and a BRAND NEW VISCOUS COUPLING in the transfer case.Runs and drives great.Also has older factory rack with wood floor strips.
This truck is not perfect but its gettin there.Sunroof works and does not leak,imagine that.Very very.small rust areas where previous owner let exhaust leak at left rear corner,driver floor board panel was replaced and is more solid than a new one.
If you are a Rover enthusiast(aka addict) you can appreciate the painstaking labor of love.The areas that need help are::small round tc light is on but doesnt seem to affect 4x4 operation at all, door lock springs sometimes drop and you have to hold up latch to get out passenger side,same for drivers side.Radio,amp and subwoofer missing since i have owned it.Driver seat motors work from bottom,meaning you can set seat position but there is a problem with seat ECM. Common on these trucks. One rear window does not roll down.Interesting Land Rover series 3,orD 90 trades... maybe.Call or text @ 828-threethree3-two22six...PLEASE DO NOT EMAIL..Grab it before all the 1995 classics are gone to pot. $5800 OBO
