2.25D won't start - Injector Pump issues?
I have an 82 S3, 2.25D that all of a sudden won't start. Usually she starts right up, but after not running for about a month, when I went to start...nothing. I've read similar threads on this message board, but still can't get it to run. Here is what I have done so far:
- Checked gas (have 4+ gals)
- Installed new battery
- Removed & cleaned fuel filter
- Bled Banjo on top of filter
- Bled 9mm screw on Fuel injector pump
- Removed distributor caps and had someone crank, still no fuel coming out
I've read that it can be a bear to bleed these out. Any ideas for what else to do? I thought about loosening banjo on pump and having someone crank to see if it further bleeds.
Also heard some people say to try and tow start it. Admittedly I have no idea how to do that, and wonder if that will help if the issue is the distributor pump.
Any way to try and isolate what the issue is? I guess it's highly probable that it isn't actually the injector pump, either :)
