Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Disco or Range Rover axles on a 110?
  1. #11
    May 2007
    Union ME
    191
    Komar... there's a name I haven't heard in a while. Tell him he left a box full of Saab turbos at the old shop.
    www.downeastcoachworks.com
  2. #12
    May 2006
    2,020
    Thumbs up
    Note that the early 110's had narrower front radius arms than the NAS Discovery, so you'll need those as well.
    2p
  3. #13
    Nov 2006
    N. York
    1,635
    KB is Kevin Buckley unless I am mistaken.
    You'd probably get by with the dosco axles particularly if you aren't really heavily laden and using a 2wd t-case. If I were building a hybrid from scratch I'd keep looking elsewhere. Land Rover made compromises in making these trucks that you don't have to.
    Land Rover UK Forums
  4. #14
    May 2010
    Rutland, Vermont
    757
    Quote Originally Posted by Les Parker View Post
    2p
    Narrower meaning the width of the arm was narrower or the distance on on the chassis was narrower?
  5. #15
    The width of the arm varies, not the length.
    Not sure if it's been mentioned, but 110s have larger diameter rear springs, so some bodgery will be needed there.
    Also, later Range Rovers/Discos tend to have dual circuit brakes on the front, where 110s had single line brakes.
    Also, as has been mentioned, the axles aren't as strong so don't load it up.
  6. #16
    Jan 2008
    Concord, Va
    111
    You only want early 110 narrow radius arms if you are using an early 110 front axle with the corresponding narrow bracket on the axle tube. Otherwise all other axles use the wider style and thats what you want. I usually just leave the radius arms bolted to the axles when I swap them.
    DividingCreekImports.com
    Tdi 130 Crew Cab x2
    110 V8 5 door
  7. #17
    May 2010
    Rutland, Vermont
    757
    A little update: I have not pickued up the 110 chassis only because the distance involved ruins a lot of the financial benefit of its cost. Right now I am considering just getting a 109 Galvanized chassis as they are ready to go and all the parts from my 109 will swap over. The exception being that I would switch to FJ60 axles.
  8. #18
    Nov 2006
    N. York
    1,635
    If you end up not using the 110 chassis you have located would you mind passing on the info on it? I am sure there are people here who could use it. Heck even I would consider it.
