I'm replacing all my rubber components on clutch/brakes system... The master cylinders were the easy part. The big problem I'm now facing is that all the metal pipe fixings are rusty and seized to the point that they are twisting & snapping the tubes when I try to disconnect them from the rubber components. I've soaked everything in PB Lockbreaker, but the metal lines are just too far gone. I've got alot more connections to break apart, and they keep failing.
So, now I'm also looking at replacing my metal tubes.
Could you guys please discuss my options for these metal pipes - it seems like it would be easier to just buy the tools necessary to make my own pipes rather than to order them all from our hosts. Any thoughts???
