Thompson,
I have seat belts. I have the lowest bracket, I have the upper bracket. What I need is the bracket that the reel mounts to..... NLA...
http://www.roversnorth.com/store/p-4...available.aspx
Suggestions??
Thompson,
Suggestions??
-L
'72 SIII SW 88"
'60 SII 88" RHD
Leslie,
That looks like just a piece of thick sheet metal. Should be easy to fab up.
67 IIA 109" NADA Wagon (sold)
Mostly... but....
It's got a jig of a little step in it, between where it bolts to the capping and then the rest of it sticking above the capping. It's just more of a jig than the sheet brake I have access to can bend on the thickness needed. Plus, there's a little bit to the bottom end where it bolts to the capping. The other option would be, to cut to pieces then weld them together, if I had a welder yet (still on the list awaiting future approval for purchase by SWMBO).
Then there's the finish. It wouldn't match the rest until I galvanized it, and there's a minimum charge @ the galvanizers, so it'd end up being expensive... if I was going to pay to galvanize it, I'd rather have it made right beforehand than half-done.
It'd be nice to have the right parts, already finished for installation, if they were available. I will probably end up fabbing something, but, it'd be worth it to me timewise to purchase, if such were available. So, I was wondering, what RN's recommendation was if I called and said I needed that part....
-L
'72 SIII SW 88"
'60 SII 88" RHD
Good news. RDS has a bunch of them. Just ordered a few for myself.. No need to fab them up..
1984 D-90 Tdi
71 IIa 88 Perkins Prima Powered
1995 D-90 SW Tdi #413
No Gas burner Here............
Randy
Leslie,
No need for a sheet brake or a welder. Just a right angle grinder, vice, hammer, and drill could make it. Paint with cold galvanizing spray, most of it will be hidden from view anyway.
Ref the seat belt fitting, the one I recommend is the RND100, this includes 2 seatbelts and buckles plus "U" shaped bracket for fixing behind the rear bulkhead. This works well if you have a soft top, having the shoulder anchors in the hard top sides does stop the belts from self tightening as you bounce down the road.
Les Parker
Rovers North Inc.
Les,
How much?
Originally Posted by Les Parker
Well, I'll ask him, but I don't think he'll be very keen. Uh, he's already got one, you see. Oh, yes. It's very nice.
Les,
Given that I already have a brand new pair of seatbelts, I really don't see spending $255 just to get a pair of brackets, eh?
And jp, I broke my angle grinder. (You know you're a Series Rover owner when, you've worn out the second one and are too poor to buy a 3rd angle grinder.... I think it's time I saved up and got an air-compressor to drive some tools to go along with the welder I'm still needing....)
Now, as long as I don't break this vice, too, I might get by....
-L
'72 SIII SW 88"
'60 SII 88" RHD
Don't buy the el-cheapo models. Spend a few extra bucks and get a good one, you won't regret it. I have an old Hitatchi right angle grinder (about 10 years old) that'll still cut your arm clean off.Originally Posted by Leslie
Try this out:
http://gotbelts.com/sebemobr.html
I ordered my retractable shoulder belts from Seat Belts Pro for our IIA. Fair price. Brackets came with kit, but the link gets you to individual brackets for sale. I used the first one shown on the web page for the back of the bulkhead to mount the retractable unit. Works flawlessly!
Greg
