Originally Posted by
Steve H
I would make sure I have such basic consumables as fan belt,radiator hoses,something to stop radiator leaks(most auto shops have stuff for this), spare water pump, spare fuel lift pump,( or kits to fix along the way if you need them, maybe you can do a buy to return if not needed with your supplier, not sure what the situation is there) check all your fluids, radiator , engine, gear & transfer boxes, diffs. Carry spare top up oils & water, check & regrease wheel bearings if need be. All standard stuff but easily overlooked in the muddle of getting ready for a big trip.
Check the condition of your drive shaft universals, maybe a good time to unbolt them & check for full & free movement, almost impossible to do in situ. Grease them up wiggle them around, grease them some more. Take along a wheel bearing kit & hub nut spanner, 53mm box spanner , I think that J33ps have/had the same size, not expensive & worth their weight in gold if you need it, save butchering nuts with cold chisels etc. Try & make sure you have every tool you could need, by 73 the Landies were a fair old mix of metric, imperial & still the odd whitworth, I'm not sure which is which, I've got most of these & used them on my SIIa when I had it (sob!) but can't remember which was which & some things had changed when S3s came along. I guess some plugs, points, condensor & leads wouldn't go astray either.
HTH, Cheers, Steve.
