Results 1 to 8 of 8
Thread: "Fuel washed" my engine = spun bearing
    Sep 2008
    Chester, VA
    435
    Angry "Fuel washed" my engine = spun bearing
    Couple months ago while on my way back from a ROAV wheeling event my truck stalled out twice on the highway. Just sputtered a bit and died but it started right back up and ran fine after that. I thought maybe a bad condenser (new aftermarket 45D) or a bit of crap in the carb. At home I pulled the top of the carb off (Rochester) and inspected it, took apart the top half and cleaned what I could and figured I'd order another rebuild kit from NAPA ($19) and clean it up correctly, especially since I ripped the gasket putting it back together. I'll also order another condensor the next day from RN.
    Drove it to work the next day (8 miles) and by the time I got there it was running very poorly, bucked in the parking lot, backfired and died. Open up the bonnet and fuel was coming out of the top of the carb! Mechanics I work with came over and found that I put the needle valve in upside down (classic potato head move) causing me to flood the engine. Fixed that and she started right back up BUT in about two minutes it developed a knock from the bottom of the engine.
    They suspected fuel wash right away and the one mechanic agreed to take it home and check it out. He finally got around to pulling the engine and sure enough, spun bearing...all because of one moment of stupidity!!!!!
    Only good thing is this guy is a perfectionst and my engine will be "better than new" when its all back together. My job is to supply the beer, clean the parts and learn. Expensive lesson but since I figure I'll be keeping this truck forever its just another Series oppertunity.
    '72 S3 88 - Leakey & Squeaky
    Apr 2008
    The Granite State (NH)
    3,435
    Not familiar with the term "fuel washed". Does this mean that raw fuel went by the pistons and down into the oil sump dilluting the oil? Can't think of any other way off the top of my head...
    Jul 2010
    Auckland, NZ
    451
    Yep. Although I have mostly heard of it in relation to diesels rather than petrols, but then again I have not encountered too many cases like that (like,.... none).
    Sounds to me you got off cheap.
    Alan
    109 Stage 1 V8 ex-army FFR
    2005 Disco 2 HSE
    Jul 2007
    Augusta, GA
    909
    bmohan,
    That stinks, but it happens. Good thing you shut 'er down when you did. Is he just going to replace the bearings, or is he gonna do a full overhaul?
    Travis
    '66 IIa 88
    Sep 2008
    Chester, VA
    435
    Quote Originally Posted by thixon View Post
    bmohan,
    While my friend has it he's going to do a full rebuild (the guy insisted on it as he is quite the perfectionist) also new clutch and anything else he sees that is easily accessable with the engine out. Chaulking it up to a learning experiance, actually I'm looking forward to helping and learning from "the master".
    Apr 2009
    Bozeman MT
    705
    Quote Originally Posted by bmohan55 View Post
    woah woah.... slow down...this doesnt mean that you'll be absent from MAR does it?
