Originally Posted by
JimCT
Give it a healthy wack with a good sized hammer. Moving the vehicle doesn't move a dead spot in the starter, it only helps if you are missing teeth on the flywheel. Not unusal for a Lucas product to need a good beating.
I agree with Jim. Use a hammer.
Rocking the truck should make absolutely no difference, as the starter is not engaged until the solenoid makes it fire. In other words, you aren't rotating the starter. If you were, the starter would be grinding the whole time the engine was running.
67 IIA 109" NADA Wagon (sold)
