Results 1 to 2 of 2
Thread: 200 Tdi
    Mar 2007
    Killingworth CT
    351
    Default 200 Tdi
    I am changing the timing belt on my 200 Tdi and I have to remove the front pulley on the crankshaft. The nut that holds the pulley on is apparently right hand thread and I have been trying for two days to get it off. I have a impact driver which will apparently put 500 ftlbs of torque to the nut and that will not get it off. I also have a massive 36" pipe wrench and a breaker bar that I have tried. Any one have any suggestions. I have been using PB blaster ever couple of hours too. I also tried heating a little with a cutting torch it and then using the driver or the breaker bar.
    Mar 2007
    Killingworth CT
    351
    got it off, I needed a 3/4" drive, it was the only thing strong enough.
