How long can I drive with...
I have, as many others, have the vibrations at around 40 and then highway speeds.
I've replaced the front shaft, rear roto and u-joint, and had wheels balanced (lug-centric).
After searching other posts, I am convinced it's the t-case bearings or maybe the diff bearing. All I know is that when I take out the front shaft (and it's new and balanced), the vibrations go away.
So, with the diff-lock engaged, is it ok to drive around on just the rear drive shaft? I was going to attempt to change out the bearing(s) myself and since I've never worked on the t-case, there will be a learning curve.
Also, does anyone know of any tools that would help out or any tricks to getting at the bearing in the case? Does it need to be dropped? Thanks for any help
