What is the proper procedure for checking the automatic tansmission fluid after installing a new filter? There is no dipstick.
Book says it holds 9.2qts, but no way to get that much into the pan without it running back out the fill hole
Automatic transmission fluid change
Refer to my other post on your thread.
Check this out, the PDF has all the instructions for the tranny.
http://www.landroverclubvi.com/rave-transmission.html
04 DII
08 D3 (LR3)
Easy, buy a DI sump while yours is off, swap it on. Refill through a true dipstick.
bad idea, filling the d1 autobox to the correct level is a real pain, the D2 fill - overflow is far simpler.
