SANTANA TYPE DISC BRAKE CONVERSION
This lower cost alternative to the RM vented brake kit is based on the Santana disc brake. It is supplied with everything that is needed to fit to the Series front axle. Two small areas 2mm x 25mm needs to be filed off the swivel housing casting to allow the calipers to fit.
Please click the "information" tab at the top of the page and go to "install guides" Disc brake and download the comprehensive illustrated guide on fitting the kit.
The Mintex pads and Brembo discs are readily available, wheel bearings (supplied)are standard Series type. For post 1980 (metric) S3 the stub axles will have to be replaced to earlier type.
Price: £569.87 (£485.00 exc VAT) · Product code: RMS050
