Results 1 to 2 of 2
Thread: the engine is hunting when she starts
    Default the engine is hunting when she starts
    Clogged fuel injector???? any ideas??
    -and how to maintain fuel injectors
    Sep 2007
    Philadelphia, PA
    122
    Default Injector Cleaner
    Quote Originally Posted by Landlover.Hunter View Post
    If memory serves me right... Land Rover's Service Manual suggests a fuel injector cleaner every other oil change added to the fuel tank at fill up.
    I typically use a cleaner every oil change. At less than half the cost of the dealers Genuine fuel injector cleaner, I use Lucas Fuel Injector Cleaner, ~$3.00 per bottle.
    For the more serious fuel injector problems... 3M makes a 3-stage cleaner solution. The local Napa Auto parts can source this product. This system connects to the fuel rail to pump solution directly to the injectors, a bottle of additive to the fuel tank and a spray for the throttle body. I've known mechanics who swear by this system. I fortunately have not needed to go this far with my Rovers.
    Genuine injectors are pricey, cleaners are not. REMEMBER!! If you need to swap out injectors... use a spot of lithium grease on the o-rings or the injectors WILL leak.
    Last edited by joshua.mcguoirk; 12-10-2010 at 05:15 AM. Reason: Additional text added.
    1990 RRC, 3.9L, AUTO "Willow Pond" (Sold)
    1996 D1, 4.0L, AUTO "Lucas"
    1999 RR, 4.0L, AUTO "Belle" (Sold)
