Page 1 of 2 12 LastLast
Results 1 to 10 of 96
Thread: Buying Rebuilt Engine Sources
    Jan 2007
    Decatur, IL
    83
    Default Buying Rebuilt Engine Sources
    My #2 cylinder has 20lbs of pressure...Everything looks good under the valve cover and assume it is either a valve or piston issue and have decided to replace the entire engine and not second guess myself. Engine has not ran real smooth since I bought the truck and was planning on putting a fresh engine in once this one gave me a sign. I do not turn my own wrenches when it comes to inside the engine and have talked with my very capable mechanic and would like to purchase a complete engine to drop in. My preference is more power and am not scared of approaching the $5k mark. Want to stay with gas. I hope you folks could recommend a good reliable source.
    Your thoughts are appreciated...
    ________________________
    67 Series II
    93 D110 NAS 327
    94 2x D90 NAS #'s 1076, 1181
    95 3x RRC 2-SWB, 1-LWB
    Apr 2008
    The Granite State (NH)
    3,435
    Our hosts sell them, though I'll be darned if I can find them listed anywhere on their site...
    May 2007
    Bloomfield, CT
    1,382
    Unless your "mechanic" is just a 'remove & replace" kinda guy, why don't you have him rebuild your engine? The 'rebuilt' engines that RN used to sell came from the Ministry Of Defense, and the rebuilder could have been very very good, or very very horrid.
    5k? You could get a complete turner enginer for that. Course you'd be wasting money. For less than half that you can have it rebuilt locally to the same effect...
    May 2010
    Rutland, Vermont
    757
    Why not just rebuild it yourself? Instead of shelling out thousands for someone else to do it...spend the money on an engine stand, some tools, and the parts. Find a good race/machine shop in your area that will be willing to give you advice and help with analysis on what needs to be done. a basic rebuild might just involve replacing the journal bearings, honing the cylinders, and replacing the rings. If the block needs more attention you might need to bore the cylinders and adjust the rings accordingly (machine shop work).
    If you have no time, space, or interest then just pay someone else to do it.
    Nov 2007
    NY
    384
    Quote Originally Posted by Eric W S View Post
    Less than half????? The machine shop work alone is around 2k for a proper rebuild and that is without buying parts. Not sure where you are getting your figures from......good luck with that.
    1971 88 (restored and as new)
    1967 88 (the next project)
    May 2010
    Rutland, Vermont
    757
    Quote Originally Posted by Bertha View Post
    Guess it depends on what is being done. Local race shop to me will lighten a flywheel for $90, do a 3 angle valve job with cleaning, and head planing as necesary, and valve seals on an 8v head as needed for $200. Not sure what they charge for measure/inspect the cylinder bores, boring, and honing on a 4 cylinder but I doubt its much more than $500 - $750. So for about $1000 you should be able to get all the basic machine shop work done. Now this bill will of course go exponential if you get into balancing, blue printing, crank grinding, knifing, extrude honing, titanium rods, forged pistons, double valve springs, etc etc....but then again this is a rover engine...you would have to be rather foolish to dump that much work into a 2.25 motor (or really friggin obsessed ).
  8. #8
    Several race shops around the Midwest. And that is a la cart service with full balancing/blue printing.
    Guess I am lucky or at least not getting ripped off...
  9. #9
    Jan 2007
    Decatur, IL
    83
    Quote Originally Posted by Terrys View Post
    Terry, I was hoping you would chime in...I appreciate your very to the point and in my opinion accurate thoughts. My mechanic can do anything but doesn't have any 1st hand knowledge rebuilding these engines....and we decided for an extra $1500ish why not just save us all the work of sorting out all the nuances that it takes to make this a pleasure to drive.
    I am currently in discussion with ACR (Automotive Component Remanufacturing Ltd) in the UK and about ready to pull the trigger on their complete 2.8L solution with complete intake including carb and header.
    67 Series II
    93 D110 NAS 327
  10. #10
    Oct 2006
    Guilderland,NY
    484
    I had an ACR Power Plus motor in my truck originally with the SU carb and intake. Honestly it was a sweet running engine and that carb setup was consistently trouble free and worked at any angle. Don't believe the hype that it is a huge upgrade in power though. Versus a tired 2.25 yes it will be a huge improvement, but it is still polishing a turd compared to a modern transplant. You will certainly be able to hold highway speed with one though.
