Your pic shows the top off, so I assumed this was how it is now. If the body is that out of whack, I imagine the doors leak very nicely...
If there is NO corrosion around the tub mounting holes and the frame is new, there is cheese in the tub, hiding God knows what. The nicest, rust-free original series trucks show corrosion around these mounting tabs, there is no way around it. Heck, my 1995 110 has corrosion all around this area!
It seems they had good intentions in mind, but no idea how to properly assemble the body on the frame, which you can't blame someone for if they haven't done it before. Honestly, the best thing to do is to strip it down, start from the rear per my earlier post, and re-assemble it correctly. It is a ton of work, but saves so much aggravation in the long run...
1995 110 Regular
