Results 1 to 3 of 3
Thread: door seal problems
    Oct 2009
    norwich, ct
    587
    Default door seal problems
    whats going on
    ive run into a couple of road blocks with my new defender door seals
    tub side galvy body cap and the lower windscreen area.
    what have others done here.
    i dont really want to cut the seal and ruin the integrity of the seal.
    im not planning on taking off the roof so it doesnt have to be removable.
    thanks
    aaron
    73 series III 88 2.5 na diesel daily driver
    67 series 2a 88 RHD sold
    88 RRC sold
    60 mga coupe
    Dec 2006
    Fleetwood, PA
    183
    you don't have to trim the actual seal just the barbed part to fit around the capping and the windshield bracket.
    Neil Hanekom
    '73 LHD 88
    '75 FFR 109 exMOD Build Photo's
    '99 D1
    Jul 2008
    Huntsville, AL
    696
    Quote Originally Posted by scatterling View Post
    Then use adhesive glue to secure it to the windscreen area.
    I cut my seals into two pieces on the rear tub and plugged up the ends with some closed cell foam then coated that with the adhesive glue (the foam plug is to keep the glue from running down the inside).
    Birmabright Brotherhood
    Take the vow, join the brotherhood!
    Clint Rankin - 1972 SIII SWB
