Results 1 to 2 of 2
Thread: Removal of interior door trim Disco 2
    Default Removal of interior door trim Disco 2
    Does any one know how to remove the door skin, Interior trim panel to replace locking mechanism??
    Jan 2010
    35
    Default Panel removal D2 front
    Seven #2 phillips screws. 4 along bottom map case, 2 in handle then the one behind inner door latch. After removal pry away panel starting at top lock button corner. You should use a panel popper for this $5.00 any parts shop. Take your time to the bottom of door then top of inside corner to bottom of door then with a box, milk crate, small child or your wife under bottom of door pop off and set to the desired support. Then unplug your speaker wires should be two. Off. There will be a plastic water/vapor sheet covering the whole thing. Carefully pull back on this trying to retain as much of the black sticky **** as possible; tape back out of your way so you can get your hands into the few holes you'll be cutting your hands on to fix this. While your in here take time to grease anything you can of the window lift mechanism because this will fail in 4 months to a year from know. Fix what you need to and reasemble starting at the top. If the black rubber window seal are lose crimp back a little tighter and add small pieces of duct tape to door where they clip on.
