1970 Series IIA 109 EX-MOD
1971 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC SWB Brooklands Edition
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 GMC 2500 Suburban
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSE
Did you consider rivnuts? The PO of my 109 SW installed them on the dash and they are terrific. I'll be using them on my project 88.
'60 SII Station Wagon
'64 SIIA 109 Regular
'68 SIIA 88 Station Wagon
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSE
very cool connector, I didn't know about those!
_________________________________________
1986 3.5l 110 SW Austrian Feurwehr
Did some more bleeding today and got a little better pedal. Brakes are all new but seems like there is still some air in there somewhere. I adjusted the 4 wheels to they were dragging and then backed off a little. Then bled each wheel until i got just fluid. Still have to pump about 2 times to get anything to work. Clutch still needs some attention as well, works but only almost against the floor. Let the engine run for about 15 minutes to let the thermostat open so i can fill up the coolant to proper capacity. Only got about 2 gallons in before it was full, bible says about 2.75 gallons i think...
Pretty neat having it outside and running for first time in years...
Did some work on the truck bed. First gave it a steam bath to get the crud off and old oil and grease that had been thrown all over it for years.
After a bath
And a coat of Waxoyl i got from RN last year to finish the bottom off. Man that stuff is messy! Probably should have worn gloves.
Left the 109 out in the sun for a while to warm things up as prep for the cavity waxoyl. Didnt make it to that today, huge thunderstorms rolled through
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSE
You can modify the front brake configuration so that the cylinder with the bleed screw is on top. Search the forum, it's been discussed before. I will sheepishly admit I have never gotten a system with the CB mast cyl to be pump-free. Early on in LR ownership I got so fed up I took my 109 to a mechanic and he couldn't even get it dialed in. I've since converted to a boosted system, and using a power bleeder, it's now a ten minute job. It might be worth it for you at this stage to take that plunge...
Spent a while taping off the door tops then painted them. Didn't try too hard as after the summer is over im going to buy some RM ones. Mine are pretty rusty and not worth much effort. Also masked off the bed and had planned on painting it tonight, again more thunderstorms. Too big to fit where i have been painting everything else and i really dont feel like setting up a ghetto paint booth in the hangar. Going to try early this morning when the wind is calm and see what i can do.
Too much fun driving it like this. Although i wouldn't mind if it was together...thats for tuesday.
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSE
Well it has been a long time since I have done anything rover. I had to be back East for Memorial Day weekend and still had a body-less rover. Then i took over a restaurant and my computer crashed, so i was off the grid. Posting was put on hold while I worked straight for 3 days and nights so I could put it on a trailer and make my ferry boat home.
Anyway here is a recap of how my build came to a finish (almost)
Painted old beat up door tops with rattle can. I plan on buying RM door tops pretty soon to replace.
Got a little wild and stained a sheet of oak plywood a bunch of times. Im going to attach the metal strips i painted on top of this and see how i like it. Always loved the look of old American pickups with wooden beds.
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSE
Took me and a buddy 2 solid 5am nights to wire the entire truck from scratch. I am so happy and shocked at how well it all came out. Very simple, safe, and no key. Just what i wanted, and it looks pretty cool i think too. I was in such a panic to get this done and leave i didnt take many pictures which im not that happy about. Here is a shot of the finished dash. No more fuses, I used aircraft breakers and 2 bomb switches to arm the car. One switch lights up everything but ignition. The second charges the ignition system and the button starts. I have 2 accessory plugs, one on either side (still need a driver side one).
During wiring i still was putting stuff together as paint dried. Got the bed painted outside hanging from the fork lift around 3am just as a thunder storm rolled in which was pretty intense. But it came out great. Put doors on and lined up pretty well considering i had everything apart.
Hoops back on! Started looking like a rover again.
Windshield and door tops. I think I had about 36 hours until I needed to be 1000 miles away on a ferry at this point.
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSE
