Results 1 to 2 of 2
Thread: SU carbs on a 90
    Feb 2009
    Elizabethtown, PA
    30
    Default SU carbs on a 90
    Hi!
    I have a customer with an early 90 (I've been told it is the second of 3 press cars from the '85 launch of the 90) that is currently fitted with a pair of SU carbs on the V8.
    The engine tends to ping and generally runs flat at higher rpm. The needle jetting in the cabs is BAK, and although I have found numerous sites for needle sizing, I haven't stumbled across a recommendation or application site.
    Anybody know what is supposed to be in there?
    Ignition timing is mostly spot on, the points and condensor are healthy, engine temperature is controlled with a now functioning electric fan, but problem persists.; have not checked coil output hot, history of engine is unknown.
    Trevor
    92 RRC, 94 DI, 06 LR3
    May 2006
    2,020
    Default S.U.Carbs
    Joe Cutro is the guy to calll:-
    http://www.joecurto.com/index.htm
    Les Parker
    Rovers North Inc.
