Results 1 to 4 of 4
Thread: 2.5 NAD oil dipstick tube measurement
    Default 2.5 NAD oil dipstick tube measurement
    Hi All (All 2.5 owners that is)
    I have a simple question, but it will require you to run to the garage and stick your head under the bonnet with a tape measure to provide the answer.
    I replaced the oil dipstick tube on my 2.5NAD because it had been bent and then broke off at the bend. The problem is that when I replaced it with new tubing and compression olive, I didn't know how far in to the engine block the tube is supposed to intrude. Can someone give me the measurement from either the top of the threaded compression fitting or the face of the engine block (please specify) to the top end of the dipstick tube? Obviously this is important to get a reliable reading of the oil level on the dipstick itself.
    Greg
    '85(?) ex MOD 110 38KF61
    Jan 2010
    1 hour North of Rovers North
    144
    put the specified amount of oil in the crankcase, and adjust the length of tube until the dipstick reads right.
    67 angry hamsters
    Oct 2008
    San Antonio, TX
    101
    Default DipStick
    Greg, looks like about 18-1/8 " top-to bottom. Hope it helps, great looking truck!
    Geoff
    http://www.flickr.com/photos/3127781...n/photostream/
    Ok, after re-reading your post, I see what your're asking. The dipStick tube, from compression fitting to top is 10-1/2 ",
    and from block to top is 11-1/8". Let me know if you need more.
    Geoff
    Default Thanks Geoff
    That did the trick. Thanks.
    Greg
