Results 1 to 4 of 4
Thread: trouble getting timing belt tight
    Default trouble getting timing belt tight
    I have been having a hard time getting the timing belt tight. I am using a breaker bar with a short extension, but it doesn't hold in the square hole very well and when I get things tight it still doesn't seem tight and jump timing after a few minutes of running.
    Any suggestions?
    thank you,
    James
    Ridgefield CT
    309
    what's a timing belt?
    Kevin
    04 XJ8
    92 RRC
    02 Benz E320
    95 RRC (sold 5/10)
    72 Series 3 (sold 4/10)
    70 Series 2A (sold 6/10)
    Morgan +8 (sold 8/09)
    90 Jetta (308k miles) (sold 5/11)
    72 Triumph Stag (sold 1/08
    May 2007
    Union ME
    191
    Quote Originally Posted by kevin-ct View Post
    Hey Kevin...he's running a diesel
    knowledge without experience is just information.... Mark Twain
    www.downeastcoachworks.com
    Oct 2008
    San Antonio, TX
    101
    Default Torque wrench
    James,
    I just put a 1/2" exntension into the square hole in the tensioner plate, and using torque wrench applied 21ft/lb to the belt. I made some wooden blocks to hold the injection pump gear and cam gear in place while tightening. Tighten the nuts to lock the tensioner once belt is at tension. Most important though is to rotate the engine 1 complete revolution and repeat.
    Hope it helps.
    Geoff
