Results 1 to 3 of 3
Thread: Mystery oil cooler hose, any ideas?
    Feb 2011
    15
    Default Mystery oil cooler hose, any ideas?
    I ordered the replacement for a Disco 200 tdi lower oil cooler hose from our host as that's what's in my 110 and it is about 10" too short and has different fittings. The last section at the "B" end is tagged "NTC 4337"Anyone else run into this on a converted vehicle?
    Feb 2011
    15
    In case anyone else runs into this, The end fittings can be taken out of the original and affixed to standard 1/2" ID hydraulic line with compression fittings. Worked well.
    May 2006
    2,020
    Default Oil cooler hose repair
    Thanks for the info.
    Do you have a pic of the fix?
    All the best
